Electronic Ignition
Phil A
06-25-2005 16:59:38
Any thoughts on installing the electronic ignition on a 49 8N front mounted distributer to solve those nagging points? Is it worth it?
Dan Kelly
06-26-2005 11:52:16
 Re: Electronic Ignition in reply to Phil A, 06-25-2005 16:59:38
Phil,
I'm with taylor, I put the flame thrower in this last winter. with a 12v neg. ground my 2N has never run better. starts the first time everytime.
Dan N nor cal
souNdguy
06-25-2005 21:29:40
If you are staying 6v.. I think it will be a dubious job. If all the components are new or in top condition.. should work ok... ( starter, battery.. etc. ) Once the battery ages.. or the starter ages and drags a bit.. volts to the ignition module will drop. Under 4ish volts.. the module won't fire at all.. unlike points.. that will fire sufficiently at 3 volts... etc.
If you go to 12v.. I think the e-ignition will realize more stability with respect to aging electrical system and ignition components.
Your machine.. but you can buy a but load of points for the cost of an electronic ignition...
Soundguy
taylormade2n
06-25-2005 20:05:37
Phil I installed the pertronix flame thrower elec ign earlier this year ,I think it is the best thing that has happened to the old beast . the tractor starts much easier and has more power than with the points.Also it is a very easy modification . P.S. mine is a 12v neg. ground sys.
hth Jason
