frount mount dist
roger powell
06-26-2005 11:46:50
posted yesterday about wireing. its fine. coil is fine per dells instructions. pulled front of dist to see if points were opening and closeing. found that the points plate was moveing around a bit. removed dist but everything checks out. bushings are fine,point plate spring in place and tight. could cam be moveing in and out? nothing looks out of round. any ideas would be help full thanks in advance
ratface
06-27-2005 06:58:51
 Re: frount mount dist in reply to roger powell, 06-26-2005 11:46:50
make sure the hold down spring clip isn't missing.
jwm
06-26-2005 17:19:36
You say "points plate is moving around a little". It should not do that. It should be rock solid. If the bushings are fine cam will not move in and out. If the points plate is moving around check the timing screw to make sure it is properly adjusted and tight. Other wise check the points to make sure the adjusting screw is not loose/stripped. James
gee
06-26-2005 15:52:45
hi, had same problem. put on electronic ignition. works fine not great just good. luck to you. later.
