Points
Pitch
06-26-2005 15:14:29
Am I just lucky or what. I have a '49 front mount that always starts. I read all the posts of folks having trouble with points wires and such not.
I've had my N about ten years now,I put new point wiring harness,plugs wires,cap on it when I brought it home just because. Since the I have changed points and cap once. I bought a new coil and bunch of other parts when Farm& Fleet went under and they just sit on the self now.
I don't do proper maintainence just a hit and lick no again and the tractor sits outside 24/7/365. Is it possible that I don't have the problems because I run it almost every day for some length of time? I know that it has never set a week with out being run since I have owned it. Just something that I ponder on everynow and again when I read this board.
souNdguy
06-26-2005 19:51:13
 Re: Points in reply to Pitch, 06-26-2005 15:14:29
My 8n has been thru 4 sets of spark plugs.. I've owned it for ? 4 years... I've 'filed' the points once.... Naa is on the same set of new points from when I got it.
my 2n is on the same set of points since i got it. My IH cub is on the same set of points since I got it.. did file once...
I have a box of new un-opened plastic baggies of points for my tractors... left over from ignition packages that have the caps and all.. I gues sone day I may actually have to change the points.. still waiting though.
One thing I'll add.. My tractors do stay under cover.. in a barn or leanto. And when i have filed the points.. I do use an ignition hone.. not a regular file. I also have 1 feeler gauge set just for points.. it stays nice and dry and clean.. doesn't get used for plugs or other things..
Soundguy
Mike OH
06-26-2005 18:37:06
The longer I"ve had my tractors the more I"ve come to believe what you say is true. The more you run and use them the better they will be. I don"t believe in abusing them and I do maintain them fairly well, but if I let them set without using them, the more likely something seems to go wrong.
gee
06-26-2005 15:48:50
luck is on your side. pappy always said if it ain't don't fix it. have a good one. later
