Occasional no-start situation...thoughts?
Paul Schultz
06-26-2005 15:32:24
I've owned my 53 Golden Jubilee about 3 months. It runs great. Starts with the push of the button. Doesn't need the choke.
Except...On rare instances I'll stall the tractor. After that I can't get it to start. I try the choke and it doesn't help. I assume I have flooded the darn thing. After sitting overnight I can get it to start right back up.
When I bought the tractor I dismantled the carb and used carb cleaner (even though everything looked fairly clean). Points, condensor, plugs, wires, coil, battery all recently replaced per the previous owner.
Do you think this is a simple case of flooding the engine or should I be looking into something specific?
Paul.
gee
06-26-2005 15:46:25
 Re: Occasional no-start situation...thoughts? in reply to Paul Schultz, 06-26-2005 15:32:24
check your float might be letting to much fuel in. also check fuel filters and blow out fuel lines. luck to you and good day.
