Engine throttle surges
Rick Bearden
06-27-2005 09:31:49
I have an 8N that when the engine is running the throttle surges up and down.
At idle you can see the arm to the govenor moving back and forth.
Jason Simmerman
06-27-2005 09:47:45
 Re: Engine throttle surges in reply to Rick Bearden, 06-27-2005 09:31:49
Does it only do it at idle or throughout the rpm range? Reason being if you don't have it idled down to far you probiably have a carb or ignition problem. Tune the carb in and if it still does it you may have the timing too far retarded. Your advance weights might also be sticking or restricted in the distro. Those are the first things I can think of that can do that.
