Dell, Yeah, I'm scratching my head on this one too! I haven't gotten back to the tractor to investigate further. But, I have come up with a modified version of my wiring diagram which is linked below. It assumes that I can find the ground from the starter and place the starter button on series on the ground side of the starter. I would use the small terminal block with one side "always hot" and the other as "key-on hot". However, since I haven't gone back and gotten details on some of the parts I need to find out: 1) Details of how the solenoid is wired up. Right now there are some small guage wiring in the original diagram. 2) Perhaps the starter button needs to go from the ground side of the solenoid? Again, I need to investigate. 3) Some folks add a diode in the system to prevent a trickle down circuit. Where would I place this? Is it necessary? 4) I have to determine the type and brand of the alternator. Or, I could change over to the Delco 10si. I am wondering if this alternator is an older Ford type? Take a look at the 'Proposed Wiring Diagram' which is based on modifying my existing set-up. Paul.
