Order Ford 8N Parts Online
8n cuts out when warm
Rick in Kansas
04-08-2001 06:12:26
Fired the old 8n up last night and did some plowing. After about 30-45 minutes it began cutting out. Almost didn't make it to the yard. Shut it off, checked the in-line fuel filter (it looked OK), put in a bottle of gas-line antifreeze and about a gallon of gas. (All gas in the tank was fresh). Let it cool off for an hour or more, then it started up with no cutting out. Everything electrical has been replaced except the coil. Think it's the coil?
Joe
04-09-2001 07:45:36
 Re: 8n cuts out when warm in reply to Rick in Kansas, 04-08-2001 06:12:26
After running for about two hours my 9N will do the same thing. Loosen the gas cap and see if it will run better instantly. My cap is unvented and yours might be the same. Good luck.
Snowplow
04-08-2001 18:16:49
Yup!
bj/8N/mt
04-08-2001 07:52:52
don't exclude the ignition switch from your list of suspects
YMMV
JimNC
04-08-2001 07:32:51
Yes Rick,
It sounds like the coil is breaking down.
