Cleanup before painting
RobertD
06-30-2005 08:57:06
What have you folks found to be good at removing all the old dirt and caked on oil and leaving a clean surface in preparation for painting? I'm talking about big stuff that can't be dipped.
Robert
DaveTx
06-30-2005 20:55:48
 Re: Cleanup before painting in reply to RobertD, 06-30-2005 08:57:06
I"ve got a recipe (that has been posted in this site before) for mixing up a cleaner/stripper. It is easy and cheap to make (much more so than oven cleaner) and it works. e-mail me if you want me to send you this as it is rather long. You can un-hide your e-mail or simply reply to this and list your e-mail.
HOOKER
06-30-2005 15:02:05
third party image
aaahhhhh h
its works
jake
souNdguy
06-30-2005 12:39:42
That purple stuff.. simple green.. oven cleaner.. carb cleaner.. etc.
Soundguy
RobertD
06-30-2005 12:50:27
 Re: Cleanup before painting in reply to souNdguy, 06-30-2005 12:39:42
Thanks Soundguy. I tried using engine degreaser in the spray can. I sprayed it on and waited about an hour. Washed it off and could barely tell it did anything. Carb cleaner sounds like it might do some good. I seem to remember it is pretty strong stuff.
Robert
souNdguy
06-30-2005 12:52:42
 Re: Cleanup before painting in reply to RobertD, 06-30-2005 12:50:27
Some of it is laqure thinner...
That purple stuff melts it good too.
Soundguy
Bama8N
06-30-2005 13:43:13
 Re: Cleanup before painting in reply to souNdguy, 06-30-2005 12:52:42
EZ Off oven cleaner from the Dollar Store. Nothing finer.
Tim...Ok
06-30-2005 13:51:49
 Re: Cleanup before painting in reply to Bama8N, 06-30-2005 13:43:13
I have decent luck with the cheap dollar store oven cleaner,scrape off the big chunks,spray it,smear it around,spray some more then power wash it..may have to do it a few times in the really bad areas,but it"ll get it clean,even takes off some of the old paint..
Tim
