HAND OPERATED TRACTOR/
Paul Walsh
06-30-2005 21:01:02
Hi. I'm looking for a tractor that can primarily be operated by hand because of my disability. Some one on this forum suggested Ford with Select-o speed trans. How does this trans work? Can pto also be done by hand/ What models does have Select-o Speed. I will also need electric start and power steering and possibly a light duty loader. What do those opf yopu that know Fords suggest. I was trying to stay around $3K but may have to adjust that some.
George Willer
07-01-2005 14:40:39
 Re: HAND OPERATED TRACTOR/ in reply to Paul Walsh, 06-30-2005 21:01:02
Paul,
I hope you don't take this other than intended... I'm working with my own disabilities. For inspiration you really should see the young man operating his tractor with no arms. He lost them both in a horrible accident. He is a serious contender in tractor rodeos operating a hand controlled John Deere B. I can't for the life of me understand how he even stays on the seat while operating with his feet, but he's an EXPERT in tractor handling.
After seeing him work a few years ago, I'm humbled!
I hope someone can tell me who he is?
tim in pa
07-01-2005 06:44:10
you should consider a tractor with hydrostatic transmission as mentioned, as all forward/reverse speeds are controlled with one forward/back lever (some are foot operated - maybe convertable to hand) at a given throttle setting. however, if you live on land with hills, some models don't provide the adequate braking when going downhill through the transmission. some case models known for that. hth
Paul Walsh
07-01-2005 20:32:06
 Re: HAND OPERATED TRACTOR/ in reply to tim in pa, 07-01-2005 06:44:10
Thanks for input and keep it coming. I'm pretty new to fords and so I'm doing research at this point but plan on doing something soon. As far as hydro's I realize that would be a good set-up as I currently have a garden tractor. I not familiar with older tractors that have hydro and frankly thought any hydro would be out of my price range. So info on hydro's or more on ford SOS is appreciated.
ZANE
07-01-2005 05:01:00
I think you should be looking for a tractor with hydrostatic transmission. That way you don't need to worry about brakes or PTO or especially the transmission because it is infinately variable speed controlled strictly with a single lever and brakes are not needed unless the engine is stopped and even then they will not roll freely.
International came out with a hydrostatic transmission in the early 70s and I am sure that there are others out there too.
I don't think the SOS would be a good selection for a handicaped person since it is next to impossible to do any slow manuvering even for the able operator. It is mostly just jump and go. Not good!
Zane
souNdguy
06-30-2005 21:28:16
I'd look for a *7* or an *8* model of the hundred series.. I.e. a 671 or 881.. etc. the *7* is te SOS with single speed pto.. and the *8* is the dual speed ( ground drive ) pto.
I would guess that even i fthe pto engage lever was low.. you could extend it with a pipe.
Brakes may be a weird issue... Might have to get your right and left brake coupled together.. then use one of those red rock manufacturing parking brake-hand-lever- cams. That would effectively give you a big lever operated hand brak onthe right side. That and a suicide knob onthe wheel, and a dash operated transmission shifter a la SOS tranny.. I'd guess you would be close. The 6*1 and the 8** will be more likely to have power steering that the 6*0 etc.
Let us know more of what you are thinking about.
I got my 660 with loader for 3500$.. so you are at least ballpark. in some cases.. the SOS tranny tractors are CHEAPER due to people not wanting them due to the fact that some of them had serious problems. Chances are if you get a working one.. it will stay working.. etc.. especially in light duty..
Soundguy
