Did ring Job now won't crank. Backfires from carb
Randy1234567
07-01-2005 13:14:02
Did a ring job new head gaskect of course and the firing order is good switched the dis,coiland cap off another 8N and it does the same thing. Turnes over but pops out of carb.and won't start. 1947 8N any ideas
Randy1234567
07-02-2005 06:59:55
 Re: Did ring Job MAY HAVE FOUND PROBLEM in reply to Randy1234567, 07-01-2005 13:14:02
#1 piston 85lb, #2 68lb, #3 Sucking #4 68lb. Looks like it's going back to Mechanic what do you think.
BillM (OH)
07-01-2005 18:57:19
 Re: Did ring Job now won't crank. Backfires from c in reply to Randy1234567, 07-01-2005 13:14:02
I would check for good spark first, then probably change points and condenser anyway. If still no go, compression check next for stuck(sticking) valve(s).Backfire thru carb is either timing off or sticking valve, and since your timing is OK with the front mount, it can only be points considerably off or sticking valves.
Jerry(AL)
07-01-2005 18:03:36
How long did it set while you were doing the ring job? A friend of mine had an 8N that sat for about 3-4 months. When he tried to crank it finally, it would backfire like you said.
I tried to help him sort it out. First thing we found was no compression at all on one cylinder and about 30 on another. Don't understand how or why but the valves had stuck while it was sitting such a short time.
jwm
07-01-2005 16:47:38
You say the firing order is right, 1,2,4,3. Check the plug wires on the distributor cap to see if it is in that order. They will act just like yours if 3 and 4 are swapped. James
HOOKER
07-01-2005 16:04:02
yer buddy just told me it was a round can coil
jake
Rob
07-01-2005 16:01:09
Clean and gap the points, set the timing, and adjust the carb idle. Get the ignition right and then turn the carb idle in 1/4 and see what for.
John N KY
07-01-2005 14:18:02
Did you remove the camshaft? If so it could be out of time with the crankshaft. If not I would do a compression check, could be and most likely is stuck valves or if you shaved the head bent valves.
Randy1234567
07-01-2005 14:21:51
 Re: Did ring Job now won't crank. Backfires from c in reply to John N KY, 07-01-2005 14:18:02
The only thing I removed was the oil pan. The cam and cranked remained in place. I will do a compression check and let you know.
Ramrod
07-01-2005 13:35:48
Firing when intake valve is open, distributor in backwards, or way off.
Ramrod
Randy1234567
07-01-2005 13:38:12
 Re: Did ring Job now won't crank. Backfires from c in reply to Ramrod, 07-01-2005 13:35:48
How could this have happend or better yet how do I Fix it
Ramrod
07-01-2005 14:18:44
 Re: Did ring Job now won't crank. Backfires from c in reply to Randy1234567, 07-01-2005 13:38:12
I'm not an 8n expert, but if it's a side mount distributor, it might be a lot like my NAA, meshing with a camshaft gear and a slot in the oil pump shaft. If your camshaft gear is timed correctly to the crankshaft gear, it has to be the distributor timing, so make sure the camshaft gear is correctly timed to the crankshaft gear, then pull the distributor and rotate the rotor half way and reinstall it.
Did you rebuild the oil pump? If so, this is highly likely to be the issue.
Ramrod
Randy1234567
07-01-2005 14:24:00
 Re: Did ring Job now won't crank. Backfires from c in reply to Ramrod, 07-01-2005 14:18:44
It is a front mount and I just checked to see if it was wrong and it can only go on one way and fit correctly.
Ramrod
07-01-2005 16:08:38
 Re: Did ring Job now won't crank. Backfires from c in reply to Randy1234567, 07-01-2005 14:24:00
Yep, you're right, disregard all I offered, and look to the experts on front mount, although the symptoms and probable causes remain the same.
Ramrod
Randy1234567
07-01-2005 16:53:07
 Re: Did ring Job now won't crank. Backfires from c in reply to Ramrod, 07-01-2005 16:08:38
There is no such thing as bad info. I would hope that you always put your 2 cents in. THANKS
