2n-lift arm trouble
paul-mo
07-02-2005 17:30:51
in down position, the the right lift arm is hitting the rear axle housing. how do you adjust the arm to clear the housing? it lifts and lowers fine otherwise.
Jeb2N
07-02-2005 18:43:20
 Re: 2n-lift arm trouble in reply to paul-mo, 07-02-2005 17:30:51
Seems that that is just the way they were. Every one i have seen has done that and there is no adjustment to get that pin up higher. The lift arms can only go over the rockshaft in one position, so you can't rotate them a notch in order to keep from hitting. Sorry.
Jeb
