To answer both of yours questions, one post below. What kind of a hub are you using? is this 10baseT ? 100baseTX? Tried two different ones, at different times of course. Any and all changes are made with computers shut down, connect items and then reboot. One Hub is Netgear PS104 Dual speed, it was the one I had used on this setup when it was all Win98SE and it had worked for ever using both printers. Each Printer has a Jetdirect attached to them at that time. So, when I took out one Win 98 machine and put in the XP Pro my problems started. The XP would not see and use the printers when just it was booted. So, on advice of a friend, I swapped out the Netgear and put in a Linksys (Cisco) EZXS55W Network switch instead of the Netgear. No help, same issue, can see both printers from the 98SE one, but NOT XP one. I can help. 1. Get rid of the Netgear thing and start from scratch. Is your hub an ethernet hub? Are all devices plugged into the hub? Did that in step two. And yes all items plugged in. 2. Do you have tcp/ip addresses in all devices? What are the addresses for each device? Big problem with the tcp/ip as I can NOT ping the new devices, I.E. the HUB, that software absolutely will not load! It starts up, starts searching the network for devices and then just quits. No error messages, not nothing. 3. Can you ping each device by tcp/ip address from your XP Pro machine? Can ping the other computer no problem. Can ping the Epson and the HP printer, when I have the ole set up running, the Netgear. But that set up requires me to have the old 98SE computer up and running and sharing those printers. The XP Pro will never see those printers or the Netgear Print Server. I am to the point now of calling some local company to come out and set this durn thing up. Wife is not a happy camper as I am on HER new computer, the XP one and she has to wait her turn. Can?t blame her really. Thanks for the questions and ideas guys,, keep it up!! Anyone of you in the Fort Worth Texas area? :-)
