Order Ford 8N Parts Online
8N clutch dimension to bellhousing bolt face
Roger in Iowa
07-07-2005 10:43:25
I need the dimension from the center of the clutch disk to the face of the bellhousing bolt circle on the engine block.
I need to drill a hole in the bellhousing for a screwdriver or other to help break the clutch disk loose from the flywheel and pressure plate.
I have tried all the other suggestions, other than spraying brake cleaner in the clutch area. Will do that when I drill the hole.
This is a front mount distributor tractor. Therefore no timing hole.
Thanks,
Roger in Iowa
Hobo,NC
07-07-2005 11:00:06
 Re: 8N clutch dimension to bellhousing bolt face in reply to Roger in Iowa, 07-07-2005 10:43:25
flywheel face sets 1/4" in from the rear of the block so you look'n like 1/8".
Roger in Iowa
07-07-2005 18:57:38
 Re: 8N clutch dimension to bellhousing bolt face in reply to Hobo,NC, 07-07-2005 11:00:06
Thanks! Gives me something to go on. I was going to go an inch or more to the rear!.
Roger
