screwy bushhog wheel
8ngreenhorn
07-08-2005 08:57:48
The solid rubber wheel on the back of my bushhog spends as much time going sideways as not when I'm going straight ahead. It's not a big deal in the field but the gravel in my driveway and the numerous ruts in my lawn are unwanted. The hub is considerably narrower than the length of the axle and the bushhog doesn't track perfectly behind the N.
Any suggestions?
SW3
07-09-2005 10:15:55
 Re: screwy bushhog wheel in reply to 8ngreenhorn, 07-08-2005 08:57:48
Mine was doing the same thing. I welded a couple vertical beeds on the tailwheel shaft to build it up. Then use a grinder to smooth it out.
souNdguy
07-08-2005 12:04:51
If the hog is staying offset to one side.. make sure that your pto shaft isn't too long and pushing the mower ver at an angle..
Soundguy
FLAcharlie
07-08-2005 09:58:37
If the bushhog is not pulling straight behind the tractor, make sure you are using those stabilizer bars, the ones that go from underneath the rear axle, not the ones for a drawbar. Best investment I've made next to the limit chains.
Tim...Ok
07-08-2005 09:07:32
Your bushing is worn or missing if it had one,or the pipe is worn that the shaft goes thru..We fixed one by pouring molten lead down around that shaft..worked good for a long time.. The one I have now was doing the same thing,I "bushed" it with a thin piece of sheetmetal wrapped around the shaft,then greased it real good,works great..
Tim
8ngreenhorn
07-08-2005 09:23:35
 Re: screwy bushhog wheel in reply to Tim...Ok, 07-08-2005 09:07:32
Makes sense. Thanks.
