OT using a home generator
Rachel
07-09-2005 11:47:25
I have a generac 5500 watt home generator that I bought for power outages and hurricanes I havent used it yet and Ive planned on just powering my refrigerator, a freezer,and maybe a box fan will I be able to use an extension cord for each item? Ive heard of people using home made double male plugs that hook up to their dryer plug etc.I dont want to install any permanent transfer systems etc.Will the extension cords work?Will the cords be safe?
R.M. In AL.
07-09-2005 22:00:17
 Re: OT using a home generator in reply to Rachel, 07-09-2005 11:47:25
I prefer to run one heavy one into the house like a 12/2 and from there hook up one of those 15 amp power plugs sticks that has all the outlets you will need then you can plug up the smaller extention cords as you need them.Works great and very safe..R.M. In AL
Tom - NJ
07-09-2005 20:04:30
I have a transfer switch that I installed that I use with a 4000 watt generac. It will run the well pump, heat ( oil burner ) 2 refrigerators, lights in 2 rooms, and TV. But you must have a transfer switch for the power & light linemans safety..... ..... .
Jay D. in NW IN
07-09-2005 14:21:05
Rachel,
I have a generator just a bit smaller than your generac and it worked GREAT during our last 14 hour outage keeping two 'fridges, a freezer, a fan and a few lights running. Since it was a summer outage, we just ran the cords through the garage and into the house. The generator didn't even flinch. I've considred the transfer switch option, but until I have a generator big enough to power the AC and then some, I'll stick with the extension cords.
J-
Coldiron
07-09-2005 12:59:37
Rachel, Like Jim said, Unless you have the transfer switch properly installed never plug your generator into a house outlet. Besides the danger to electrical workers, if the power were to come back on, the generator would not sychronize with the power gird and it would destroy your generator. Your extension cords should be at least a 12 ga with multiple plugs on them so you can split the power to the needed uses. Use duct tape to cover the door or window crack your cords run into the house from and you will be comfy. Remember to let the engine cool before refueling and don`t start it with a load on it.
Jim Cox
07-09-2005 12:06:37
using the 'dead man's plug' is probably illegal where you live. You can spend a few hundred for a proper transfer switch, or just run a few extension cords. The extension cord route is really simple, and is about as safe as you can get in a short-term situation. Why risk the life of an electrician somewhere down the line with a dangerous short-cut? Is any amount of groceries worth that?
Jim Cox
Generator User
Tornado Survivor 2003
guest
07-09-2005 15:34:19
 Re: OT using a home generator in reply to Jim Cox, 07-09-2005 12:06:37
I have a pole mounted transfer
switch that shuts off the main
power to the house, barn, and
garage. There is a 50 amp connector
that becomes connected to my side
of the switch. I just turn off breakers
not necessary and power up the gen.
Only problem is that there is no way
to know the power came back on.
George
steveormary
07-09-2005 16:14:56
 Re: OT using a home generator in reply to guest, 07-09-2005 15:34:19
Extension cords will wor just fine. Always be careful.
On the transfer switch you could mount an indicater light that would let you know when the power comes back on.
steveormary
