12v work light
Paul in MD
07-11-2005 17:56:18
Anybody know if it's possibe to buy just the 12 volt sealed beam for the work light? I'm converting my 49 8N from 6 to 12 volts and everywhere I've looked it seems they only sell the entire assembly. This is the only problem I've encountered so far. Thanks.
Paul in MD
07-12-2005 08:39:41
 Re: 12v work light in reply to Paul in MD, 07-11-2005 17:56:18
With the part number, I just did a Google search and found a bunch of places that stock it. Thanks for the help. The closest TSC to me is an hour drive and that's too far to go for a $7 part. Thanks to each of you for your help. Great discussion board!
souNdguy
07-12-2005 08:10:14
TSC and napa have tehm
Soundguy
Jim.UT
07-11-2005 20:07:46
A 6 volt sealed beam lamp with two terminal posts for the wires is a #4019 (35 watt). Equivalent 12 V lamp is a #4419. Around here you can get the 12V 4419 lamps at CAL Ranch stores for about $7.50. The 6V 4019 lamps are tougher to find.
jwm
07-11-2005 18:43:55
Have you tried auto supply houses? James
