ID Ford NAA hydraulic pump
Paul Schultz
07-20-2005 05:38:26
I believe I have the piston type pump on my tractor. But since I"m new to this could someone confirm for me...
It has near one end: NCA 9058 (the 8 may be a 3)
Thanks,
Paul.
Ramrod
07-20-2005 12:23:51
 Re: ID Ford NAA hydraulic pump in reply to Paul Schultz, 07-20-2005 05:38:26
NCA-905-C would be the gear housing for the piston type pump, I don't see a NCA9058 or NCA9053. A piston pump is kinda shaped like a starter.
Ramrod
Fessman
07-20-2005 06:11:07
The piston pump is round(ish) and the vane pump is square(ish). The vane pump also has an flow control adjustment on the end of it. The pison pump does not.
Fessman
Randall(AL)
07-20-2005 06:11:04
The vane-style pump has a "variable flow valve" on it. It is a valve that has a thumbwheel on it like a quarter to adjust the flow. Are you having pump problems or something?
Paul Schultz
07-20-2005 19:14:21
 Re: ID Ford NAA hydraulic pump in reply to Randall(AL), 07-20-2005 06:11:04
I definitely have the piston type pump as suspected.
Randall, I haven't had time to narrow down my hydraulic problems since I've been busy with work. I just wanted to become more familiar with the components of the system. I'm going to try to isolate what area of my system is causing the problem.
Thanks for everyone's help.
Paul.
