pto
508n
07-24-2005 14:58:32
I have another problem. I got a new pto shaft cause mine was bent. When I pulled the old one out, according to the fo-4 manual mine looks like a 39-43 shaft. I got a new shaft for a 1950 8n 43-52. It goes in but I can"t get the pto out of gear. If I loosen the bolts on the pto retainer it will come out of gear and slide the shaft out about an inch. I no this tractor is a mix and match. No. on the rear section is K1991, the pump says 3-30-48, trans is 4 spd. have draft cont. knob. What is the problem? Thanks all.
Dell (WA)
07-24-2005 20:24:07
 Re: pto in reply to 508n, 07-24-2005 14:58:32
The latest 8N variant of the PTO shaft if backwards compatable with the earlist 9N's PTO shaft; isn't that amazing?
As to WHY you are having PTO shifter interferance problems, you're there, I'm here and haven't gotta clue. I flunked mindreading, just ask my ex-wife of 32yrs.
You may need to be a real mechanic and "improvize" a shim scheme (think flat washers) to gitt enuff PTO shifter lever space so yer new PTO shaft will fit.
NEXT TIME, be certain to use an Over Running Coupler (ORC) when you brushhog so you don't bend yer NEW PTO shaft..... ...respectfully, Dell, the self-appointed ORC SAFETY PREACHER
