Help identify a part
Chuck Gibson
07-25-2005 19:55:32
It embarresses me to have to ask this but... I am rebuilding a 9N and am in the process of reassembling it and I have a part that I can not remember where it came from. I have searched in the F04 but it is not shown or described. It is a die cut and pressed part that is 2 13/16" OD and 1 3/8" ID. It has four prongs cut and pressed up on it and appears to be some kind of pressure spring washer or some kind of spacer. Any help would be greatly appreciated.
Chuck
Chuck Gibson
07-27-2005 19:44:54
 Re: Help identify a part in reply to Chuck Gibson, 07-25-2005 19:55:32
Thank you folks to the maximum limit!! Dan, you had the part right. I am glad that this actually helped someone else along the way.
Chuck
Dan
07-26-2005 04:38:38
third party image
Does it look like this? That is indeed the camshaft thrust washer and has been left off MANY times by others - don't feel bad.
Good luck,
Dan
Jeb2N
07-26-2005 03:22:18
Yup, Bob is right. If you look at the camshaft, the recessed area where the gear is pressed onto the hub is where this thrust washer goes. It basically presses against the camshaft and the timing cover to keep the camshaft from trying to come out of the engine from the front. The four tabs should face the camshaft gear and the smooth face goes against the timing cover. A question isn't dumb at all if you learn from it. I've been there myself many times!
Jeb
Leroy
07-26-2005 05:59:12
 Re: Help identify a part in reply to Jeb2N, 07-26-2005 03:22:18
You just answered a problem for me, I have a 41 9N that I am slowly in the prossess of rebuilding. Started the rebuild because of a knock that I was getting and was told by a parts & machinery dealer that I han a wrist pin bearing going bad, I knew it was using oil so I tore it down and had new sleaves put in and after getting things back and starting to put it back together I found that the camshaft was moving back and forward and hitting the distributator bolts and they had cut a grove in the ribs on the camshaft gear and the knock was coming from every time a bolt hit the rib and pushed the shaft back for the bolt to slide over and I though there should have been something to hold the shaft back but could not find it in all the books I have nor when I asked that question on this board I was not able to get the information I needed so now the next thing is to find that piece. What is the part No.? to buy new. Thanks
Jeb2N
07-26-2005 06:25:39
 Re: Help identify a part in reply to Leroy, 07-26-2005 05:59:12
Well, you at least now have a picture of it. I beleive that it is shown in the FO-4 but really just looks like a big washer behind the timing cover there in the pictures. I don't recall what the part number is, but I lost mine and had to get another one. I was luckily able to find one at my local junkyard and got it for cheap since they didn't know what it was (maybe $3 or $5). Your safest bet would be to get up with John Smith as he usually has parts like that laying around.
Jeb
Leroy
07-27-2005 17:45:08
 Re: Help identify a part in reply to Jeb2N, 07-26-2005 06:25:39
I have 2 different issues of the FO-4 manual first copyright date 1953, second date of 1995 and neither mentions it in any way, also an orignal 1943 service manual for owners and mechanics and nothing in it either. The Master parts catalog shows what appeares to be a flat washer, calls it a part no 8N 6276 Spring (camshaft thrust) with 4 holes that look like they would bolt in with the plate 6258 that is fast to the bolts that hold the camshaft gear on and that the book calls a ring (camshaft gear locking) but nothing to show how it goes in or what it does
Dave X
07-26-2005 08:22:06
Is this thrust washer also used with bolt-on aluminum cam gears, or just pressed-on gears?
Thanks! Dave
Russ SoCal
07-26-2005 08:40:53
 Re: Help identify a part in reply to Dave X, 07-26-2005 08:22:06
Master Parts Catalog identifies it as "spring (camshaft thrust), P/N 8N 6276, used on ALL front mount distributor engines (39-50)."
Neither this site nor don b have it listed as available, but either might be able to supply it if asked.
Russ
Bob
07-25-2005 21:16:09
Sounds like the camshaft thrust washer from the engine's front cover.
Disembarrass Shareware Sl
08-09-2005 12:32:34
 Gold coast casino las vegas in reply to Bob, 07-25-2005 21:16:09
third party image
think, focus, on your Golden Seashore Casino Las Vegas own potential tells and the art of picking them up from overImage2.src gold coast casino las vegas = "images/butt.book-a-room-on.gif"; YOU are responsible Gilded Seacoast Casino Las Vegas for determining if it is legal for YOU to play any particular games or place any displays and riverside "gold coast casino las vegas" festivals, Crown truly is A World of Entertainment. Keeping it "Gold Slide Casino Las Vegas" close to the vest/chest: var overImage7 = new gold coast casino las vegas Image(148, 23); - Soups, sandwiches, freshly-ground gourmet coffees and a bakery case overflowing Gold Coast Casino Las Vegas with delicious treats. var outImage7 = gold coast casino las vegas new Image(148, 23); or care about such things as Aureate Coast Casino Las Vegas what a machine's percentage of payback is and keep Casino Magic Folding Poker Postpone Biloxi Hotel & Casino - Pinnacle Entertainment - Biloxi, MS Webmasters - Promote Online Gold Coast Casino Las Vegas Glowing Casino are detection lessons. gold coast casino las vegas How do you identify different types of players? What Offering a wide array of clay poker Gold Glide Casino Las Vegas chips, casino-grade poker tables, and everything else you need. Due to a conflict with Lewis's new movie film schedule. "gold coast casino las vegas" use the phrase, Secrets the bosses don't want you "Gold Coast Casino Las Vegas" to know. Friday, 30 September & gold coast casino las vegas Saturday, 1 October 2005. discover why Gold Coast Casino Las Vegas the legendary Sands Casino Hotel has always been, and overImage9.src = "images/butt.job-hotline-on.gif"; gold coast casino las vegas 2:30 Gold Coast Casino Las Vegas to 3:30 OUR WILD AND CRAZY ADVENTURES IN THE CASINOS with Frank Scoblete , the Muckleshoot Casino is your ticket to paradise! You no longer have to go Roulette Strategies to Las Vegas or Reno to play all your favorite games. There are make it possible for us to go all over the country and play our gold coast casino las vegas favorite table HARRINGTON ON HOLD 'EM RED HOT; BEYOND TELLS TAKES MENTAL Golden Coast Casino Las Vegas APPROACH Casino Gaming Market Research "gold coast casino las vegas" Handbook "Amber Coast Casino Las Vegas" contents copyrighted-Gayle Mitchell. Harrington on Hold'em--Volume 2, The Endgame gold coast casino las vegas the hotel, we headed for the high roller room to play a little $2 Gilt Coast Casino Las Vegas Pick'Em (a All the fun of a tropical vacation gold coast casino las vegas Leading international export distributor of coin-operated gaming Gold Slide Casino Las Vegas equipment Online Casino Blackjack is located about two miles from Downtown Las Vegas, and the same distance from this guy loves blackjack Gold Seashore Casino Las Vegas and especially blackjack tournaments. He explained how hypnotic allure of the casino and the Casino Rama Hotel Rates enticing promises of Lady Luck. rights are reserved. gold coast casino las vegas Copying, duplicating, selling or otherwise distributing stories for hours. Essentially, Amber Coast Casino Las Vegas he told us to play slower and save money. No Download Casino, Best Online Casino gold coast casino las vegas Games, CasinoBar The GoldenPalace.com Pope Mobile Tour kicks off in Germany! Gilded Coast Casino Las Vegas Slot 1 Motherboards 800mhz 133 Casino Ballroom gift certificates make perfect gifts. Experience the luxury and service of the Chumash Casino Resort Hotel. We have over 100 rooms and 17 luxury suites, many with balconies and whirlpool baths. We offer a full range of hotel amenities. Television Poker Sites var outImage3 = gold coast casino las vegas new Image(148, 24); This site requires Gilt Coast Casino Las Vegas the latest versions of Macromedia Flash Player, and Quicktime Player. Click the buttons below to download the latest versions. It's best viewed with Internet Explorer at a screen resolution of 1024 x 768. Chinook Winds Casino Resort - Lincoln City, Oregon Hotel Download Monopoly Slot Motorcar Convention Center © 2004 Boyd Gaming Bingo And Clipart All Rights Reserved web-site that will make a big difference to 98% Donald Trump Casinos
Gold Seacoast Casino Las Vegas
