rear snowblower model # and $
Al L. in Wisc.
07-26-2005 17:26:11
I have a rear snowblower that I want to get rid of but don"t know the model/brand/value. It is red and white and is used on 2N"s. Unit is backed into the snow. Also, what is something like this worth? Blower has two paddles/blades below chute and from above looks like the letter V. Thanks for any input - what a time to sell a snowblower!!
stevo
07-26-2005 20:56:43
 Re: rear snowblower model # and $ in reply to Al L. in Wisc., 07-26-2005 17:26:11
I maybe would be interested if you are not too far...I am in minnesota...do you have photo?
RWK in WI
07-26-2005 17:57:08
If the unit is designed to be backed into the snow it is likely an ARPS unit. They were made in Wisconsin. If the unit is made so the frame can be unbolted so the unit can either be backed into the snow or pulled behind the tractor with the opening facing forward it could be an Erskine , made in Minnesota or Allied, made in Canada. The reversible units are more valuable and often go as high as $500. or even more. I hope this helps you.
