Order Ford 8N Parts Online
Hole in the side of my 8N trans case.
Pat Landy
07-27-2005 16:01:31
I was pressure washing my 8N and all of a suddent a hole appeared in the left side of the transmission housing.... Seriously, at first the red paint disappeared and an instant later there appeared to be a yellowish circle then a hole about 1 1/4 " in diameter appeared.... I surmise that someone drilled a hole and later bondo'd it up and painted it..... My question is, why would you cut a 11/4 inch hole in the side of the transmission case..... looking in I can see what appears to be the clutch return spring.....
Thanks Pat
2fordsmike
07-28-2005 08:07:37
 Re: Hole in the side of my 8N trans case. in reply to Pat Landy, 07-27-2005 16:01:31
Tractor traders will sometimes buy a Ford tractor and "mine" the valuable parts from it; then sell the tractor for "only $200 more than I paid." I bought a Sherman at a premium price that (I later learned) had been "mined" from a 641 Ford. I bought an 8N with a hole for the Sherman stick and, after I made the deal, saw the Sherman sitting in his barn. Mike-Iowa
Julian in Charlestown, IN
07-27-2005 18:02:35
I'd say thats what it is as my 41 9N has the Sherman transmission.
Julian
07-27-2005 18:07:50
 Re: Hole in the side of my 8N trans case. in reply to Julian in Charlestown, IN, 07-27-2005 18:02:35
I don't know how my reply ended up at the top, should have been behind Mike OH post ?
Julian
Scott(Ks.)
07-27-2005 17:25:39
These guys are probably right, but once my Dad took an 8N to the shop for a stuck clutch and they drilled a 3/4" hole in the housing and popped the clutch loose. They then just put a rubber plug in the hole.
Jack - Illinois
07-27-2005 16:12:07
My guess is that at one time it had a Sherman aux. transmission in it.
Mike OH
07-27-2005 16:10:31
Someone probably removed the Sherman transmission and plugged up the hole where the shifter lever came out of the housing. My neighbor's 51 8N has a hole in it where the Sherman was removed. He just left the hole open.
