Square holes for carriage bolts
Ramrod
07-28-2005 13:14:24
I finally located some fine thread grade 8 carriage bolts for my new rear fenders, which have only one round hole for the 1/2" rivet. How do I get the square 3/8" holes I need for the carriage bolts cut in there? I can't find my 3/8" square drill bit!
Ramrod
Stickler
07-28-2005 17:55:37
 Re: Square holes for carriage bolts in reply to Ramrod, 07-28-2005 13:14:24
And if you were a business that did this type of thing all the time, you'd spring for a square hole punch, I think Greenlee makes them. They're pricey, but slick. We have them and rectangular hole ones at work.
TIMW(PA)
07-28-2005 16:29:10
third party image
RamRod...I always use a tapered square file. Tapered end can get into the round hole and start squaring it off. They come in different sizes. This link and image is for a 1/4" one. HTH Tim
Ramrod
07-28-2005 16:53:07
 Re: Square holes for carriage bolts in reply to Tim PloughNman Daley, 07-28-2005 15:54:26
I found the bolts at Des Moines Bolt. They have a web page. They are not stainless, grade 8 bolts in white, not yellow zinc. You can't do grade 8 in stainless as far as I know. I'm unable to document which bolts were originally in the NAA rear fenders, can't find them in my book. Anybody know for sure?
Ramrod
Dan
07-28-2005 16:14:48
Tim - he is talking about the bolts that hold the fender skins onto the support brackets, not the LOOOONG carraige bolts that hold the entire fender onto the tractor.
Also - I got some 5/8-18 carraige bolts and nuts a few days ago from a very well stocked hardware store called Elliott's to hold the rear wheel centers to the rims on Rustbucket. They had them all the way up to 6".
Dan
Jeb2N
07-28-2005 16:40:01
 Re: Square holes for carriage bolts in reply to Dan, 07-28-2005 16:14:48
I think we are all a little confused. To my knowledge, other than the bolt that holds the light to the bracket, there were NO carriage bolts originally called out. The fender bracket-to-axle bolts were regular hex head bolts. The three bolts in the front and rear that attach a light bracket to used regular hex-head bolts, washers, and nuts. The round head fasteners that were used at the bottom and center holes were RIVETS. Most people when doing a fender skin replacement use the hex button head bolts...looks like a carriage bolt but no square shoulder and has an allen wrench socket in the middle of the head to hold it. Just fill in the hole and paint over it. I used carriage bolts and just let them pull themselves through the metal and cut their own holes. Didn't have any problems.
Jeb
07-28-2005 17:42:14
 Re: Square holes for carriage bolts in reply to Jeb2N, 07-28-2005 16:40:01
Hiya Jeb-
I read the post too fast...you're right. The fender to skins were hex heads and rivets. The fender to axle trumpet bolts were hex heads up until the 1949 8N when they were indeed changed to carriage bolts. Fenders had square holes, but I'm not sure if the trumpets were cast square too. My '48 8N would not accept a carriage bolt no matter how much I tried to force it. I also missed the grade 8 part duh! Stainless??? I need to read more carefully...
Tim
Jeb2N
07-29-2005 03:23:38
 Re: Square holes for carriage bolts in reply to Tim PloughNman Daley, 07-28-2005 17:42:14
I always wondered what the equivalent grade is on a Stainless Steel bolt. STronger than a grade 2 shear bolt, but is it about the same as a grade 5 or is it weaker? I have wrung off several brand new SS bolts (7/16" shank) using a single open ended wrench and that got me thinkin.
Thanks for the heads up about the fender/axle bolt change in '49. I was not aware of that. Now, i'm trying to think back as to whether or not i took my bench grinder and ground down the corners of the square shoulder on the carriage bolts or not. I'm starting to think I did but there was enough "meat" left to where they almost wedged themselves in place when they bottomed out and I had no trouble keeping them from turning.
Jeb
H Kutzler
07-28-2005 15:12:10
I would use button head bolts. They dont need a square hole and you can hold them with a allen head wrench in the center of the head
Russ SoCal
07-28-2005 15:37:59
 Re: Square holes for carriage bolts in reply to H Kutzler, 07-28-2005 15:12:10
Then fill the allen wrench hole with bondo. Could use JBWeld if yer never gonna remove 'em.
Russ
Dan Kelly
07-28-2005 15:05:24
Ramod,
I'd just use the carrage, the grade 8 should cut its own square hole thru the softer skin.
Dan
Dan
07-28-2005 13:44:03
Which bolt holes are you talking about - the skin to the supports? If so, you could lay the bolts where they go in the skins and with the supports installed to ensure the bolts are lined up correctly - then wack the head of the bolt good so it makes an impression on the skin metal. Then remove everything and use a cold chisel to square the marks out.
Sounds like a lot of work to me, I would just use cap bolts.
Dan
Ramrod
07-28-2005 14:08:55
 Re: Square holes for carriage bolts in reply to Dan, 07-28-2005 13:44:03
I was going to use standard grade 8 3/8" hex bolts until I saw RustBucket with its painted head carriage bolts looking soooo gooood.
