Order Ford 8N Parts Online
8N eating coils
8NPuller
07-29-2005 18:44:35
Whats wrong with my 1950 front dist. 8N? I put a new coil on use it all day no problem, next day dead coil again.
RoNofohio
07-30-2005 05:48:24
 Re: 8N eating coils in reply to 8NPuller, 07-29-2005 18:44:35
Took mine into a tractor repair/parts house to see why mine was doing the same thing. I burned up two coils in a two year period and was using the ballast resister (one of the coils was a 12 volt). The old Ford mechanic told me to install an additional resister in series with the existing 'ballast' resister in order to limit current flow. This was even tho I was using a 12 volt coil on a 12 volt system. I did so about 6 months ago and have had no trouble starting on the first turn of the starter ever since. It's probably the cheapest insurance policy you can buy. JMHO...Ron
Dell (WA)
07-29-2005 20:26:31
Puller..... ...many miss-guided shadetree mechanics "by-pass" the "infamous ballast resistor" for "HOTTER-SPARKIES" in an ill-informed belief that the reason they can't start their squarecan 4-nipple frontmount N-engine is it needs hotter sparkies. WRONG!!!
A NEW squarecan ignition coil will run for couple of hours before it melts its internal insulative tars and shorts out its windings and causes weak sparkies. Normally, an overnite cooldown will solidifiy the insulative tars and return the sparkies for about another 1-hr of running time.
Bottom line, the squarecan frontmount ignition coil requires the "infamous ballast resistor" or it DIES. The ballast resistor is mounted on top of a 3-terminal "T-block" under the ampmeter..... ...Dell, yer self-appointed sparkie-meister
Mike D Venachowsky
07-30-2005 08:43:58
 I Agree in reply to Dell (WA), 07-29-2005 20:26:31
third party image
I had to recently replace my coil, it had the same problem.
Thanks,
Mike
R.M. In AL
07-30-2005 13:04:49
 Re: I Agree in reply to Mike D Venachowsky, 07-30-2005 08:43:58
Mike I love that tractor of yours it shows it has earned respect.Plenty of character.lol.. R.M. In AL
Grove
07-29-2005 19:52:20
Is it 6 or 12 volt? If it is 6 volt system exactly what Old said. If it is a 12 volt system then you may need to add an additional resistor based on your setup.
old
07-29-2005 19:21:25
Resistor is shorted or not there any more.
