need help with these numbers.
r. allen
08-01-2005 17:35:43
i inherited a 8n tractor i hope, see if yall can help me. sitting in the seat on the left side of the rear most part of the block the best i can read are # naa8I052 there is a diamond at the end.there is a # on the right side of the block that says EAE-6015-f it has a side mounted dist. 4-blade fan and its a gas burner. both brake pedals on the right side and clutch on the left. left side has a louvered panel on the cowl. it has the pto engage on the left under the seat, and another lever on the right side under the seat.the throttle is on the right side under the steering wheel.if anybody could help tell me what year it is i would appreicate it alot. OH the front medallion has a what looks like a corn stalk with 12 stars surronding it. thanks roger..
Dan
08-01-2005 18:29:04
 Re: need help with these numbers. in reply to r. allen, 08-01-2005 17:35:43
You have a 1954 NAA. The 1954 models started with serial number 77475, so your tractor was probably made around Feb 1954. These are great tractors, as a matter of fact I just got done fixing one up from the dead. If you have some free time, click on the "Your Stories" ling on the left side of the page and read about my experience "Bringing Old Iron Back From The Dead". Or, click the link below for a photo log of by project.
Congrats on the great tractor!
Dan
r.allen
08-01-2005 18:45:11
 Re: need help with these numbers. in reply to Dan, 08-01-2005 18:29:04
thanks dan, my dad left me this tractor when he passed away. i was with him the day he bought it 1985. along with a bushhog and a set of disc. the only thing he done to it was replaced the tires on it, an swapped the orignaly seat for a cushioned seat. i got it in jan. and had to replaced the rear main oil seal (that was a fun job)and now i am replacing the pto shaft seal,started to leak sat. at the hunting club.my goal is to restore it back as close as possible. all the sheet metal is in excellent shape except for the front two side peices that let the front piviot over, they are rusted at the bolt holes.well i have carried on long enough, but thanks for the info.. roger.
