ORC
ORC
08-07-2005 06:01:08
I just installed an ORC on my 8N. To make it fit I had to take out a metal washer/gasket/insert. On my other 8N I did not have to do anything. Does anyone know what that insert was for and if it should have been removed? It looks like some type of seal for the PTO.
FLAcharlie
08-07-2005 11:14:38
 Re: ORC in reply to ORC, 08-07-2005 06:01:08
"To make it fit I had to take out a metal washer/gasket/insert"
Any chance one of your PTO shafts is 1 1/8" (original) and the other is 1 3/8" (more modern and preferable today) ?
ORC
08-07-2005 12:43:42
 Re: ORC in reply to FLAcharlie, 08-07-2005 11:14:38
The ORC does convert the PTO from 1-1/8 to 1-3/8, that is not what I am talking about. To get the ORC to go on far enough to get the spring pin in I had to take the insert out, it is a round washer type item that goes around the PTO shaft. It seems to be working and there is no leakage so I guess it was just there for looks??
FLAcharlie
08-07-2005 15:46:24
 Re: ORC in reply to ORC, 08-07-2005 12:43:42
I have two different ORC's, both of fairly different design, and neither use any insert thingie like you are describing. My impression is, if you got 6 ORC's from different places, they'd all be a bit different.
