LOG SPLITTER
RAVI
08-08-2005 06:06:56
I WAS THINKING OF BUILDING A LOG SPLITTER BY PURCHASING A PTO DRIVEN LOG SPLITTTER PUMP FOR MY 8N, BUT I HAVE BEEN GIVEN A SMALL GAS DRIVEN 11HP ENGINE WHICH HAS A VERTICAL SHAFT. ALL THE LOG SPLITTERS I HAVE SEEN USE A HORIZONTAL SHAFT. CAN A VERTICAL SHAFT ENGINE BE USED ?
hvw
08-08-2005 11:20:25
 Re: LOG SPLITTER in reply to RAVI, 08-08-2005 06:06:56
third party image
Your vertical shaft engine will work fine. A good many of the new splitters are built with those engines. I built a self contained splitter out of a 3pt model. I left the lift points on the splitter so I could more easily move it around and put a hitch on the front also. Been real happy with it.
Bob
08-08-2005 06:19:07
A hydraulic pump should not be position-sensitive, and should work equally well with a horizontal or vertical shaft engine.
