PTO Shaft
ORC Guy
08-08-2005 13:48:15
I had to take an insert/seal/washer out of my PTO shaft to make the ORC fit. Does anyone know what this is for? It was not on my other 8N. It is a metal washer looking insert that fits around the PTO shaft and was set back in the housing. With it on the ORC would not go on far enough. I have not had any leaks and it seems to be working.
Rob
08-08-2005 16:08:01
 Re: PTO Shaft in reply to ORC Guy, 08-08-2005 13:48:15
I can"t see where there is a loose washer on the PTO shaft. Is it splined? How thick is it? ID? OD?
Describe it if you can"t take a picture.
Or, you can wait for Dell and maybe he can read your mind.
ORC
08-08-2005 17:21:40
 Re: PTO Shaft in reply to Rob, 08-08-2005 16:08:01
It is about 1/2" thick and fits around the PTO shaft so the inside diameter of the opening is about 1-1/4 and it fills the PTO housing so the OD would be about 3". Hope this helps.
Rob
08-08-2005 18:14:09
 Re: PTO Shaft in reply to ORC, 08-08-2005 17:21:40
Got me. What is that thing?
