Order Ford 8N Parts Online
8N Shutting down under load
SamGeno
08-12-2005 10:07:14
I have an early (front mounted distributor 12 volt) 8N Ford with a rear mounted 6' finish mower. Lately, when the tractor is operated for about 15 minutes I notice loss of oil pressure then the tractor begins to stall (acts like it's running out of gas) then shuts down. The tractor will start again and run fine as long as no load is applied. If load is applied it will shut down again. After it cools off the process will repeat. Here are steps I've taken: changed coil, plugs, oil and oil filter, fuel filter, new gas line, gasket in sediment bowl and clean bowl. Any Help?????
timberlake-Dan
04-11-2006 08:16:28
 Re: 8N Shutting down under load in reply to SamGeno, 08-12-2005 10:07:14
I have a 49 Ford 8N that is doing a similiar thing. I bought it last fall and did not have any problems. I changed the oil. Now the tractor starts fine and the oil pressure is about 50. After running the tractor for 20 minutes the oil pressure goes down to slightly above 20psi then the tractor stalls under load acting like it is getting no gas. The tractor will continue to run in nuetral but if I try to drive her she stalls. I can let her sit for 10 minutes and she will start and run fine .... for a little while. It seems like the stalling cooresponds to low (20) oil pressure but maybe not. Does this sound like your problem?
Ballox
08-15-2005 16:41:00
I have the same issue with my side mount 8N. Idles oh but when a load is put on it ,acts like it"s not able to get enough gas. Changed plugs(autolite 437),wires,oil,cleaned glass bowl sediment(found no screen filter at bowl).
(is there another filter in the tank , How do i get it out)
Mike
Dell (WA)
08-12-2005 22:19:25
Sam..... ...ya gotts WEAK SPARKIES, that is why it is shuttin' down under LOAD. There are 4-common runn-time issues with the 4-nipple frontmount N-Engine.
1) runs for about 1-min and quits; restarts after about 15-min; bad condenser
NOT yer stated problem
2) runs for about 5-mins and quits; restarts after about 15-min; clogged fuel filters (3ea)
4) runs for about 1-hr and quits; restarts after overnite cooldown; bad ignition coil
3) runs for about 15-mins and quits; restarts after 1/2hr cooldown
Sound like yer stated problem?
BAD IGNITION SWITCH GUTTZ!!! Do I haffta tell ya to replace yer weaksister ignition switch? $10, cheap..... ..respectfully, Dell, yer self-appointed sparkie-meister
samGeno
08-16-2005 06:38:38
 Re: 8N Shutting down under load in reply to Dell (WA), 08-12-2005 22:19:25
Dell,
When I jumper around the ignition switch and run the tractor she still shuts down after about 10 minutes. Can I assume the ignittion switch is OK?
Wi Craig
08-12-2005 16:02:03
You didn't say if the govenor appears to be working correctly. Just a thought. It may need some work. Craig
bgs
02-15-2006 14:21:24
 Re: 8N Shutting down under load in reply to Wi Craig, 08-12-2005 16:02:03
govenor is working but motor will not increse in rpm
old
08-12-2005 11:08:21
My guess is that you have carb problems. I'd do a carb rebuild. Make sure you soak the carb over night at least if not longer if you do the rebuild your self.
