gallons per acre
philm
08-17-2005 17:45:44
anyone ever figured out how many acres can be brush hogged or plowed on a gallon of gas?
souNdguy
08-17-2005 18:25:35
 Re: gallons per acre in reply to philm, 08-17-2005 17:45:44
Compair that to about 5g of diesel, in about 2hr45m, and 9+ ac on my 90hp NH 7610s.
I'm burning more diesel per hour..but less fuel per ac...
Soundguy
Jerry (AL)
08-17-2005 19:44:14
 Re: gallons per acre in reply to souNdguy, 08-17-2005 18:25:35
That's pretty good on a tractor that size. I have a MF255 that I do most of my hogging and tillage work with. I use the 8N with the planter and cultivator on my deer corn.
I had always heard how little fuel a MF255 uses and it was true. I have filled the tank up only one time this summer and still have over a half a tank. Have cut around 9 acres of pines about 3 times. Haven't really ever checked it for sure but doesn't use much fuel at all.
I bush hogged about 35 acres with the N one time and then bought the other tractor. I forget how many tanks of gas I used. I cut it with the MF255 and it was about 1/3 of the gallons used. From a fuel perspective, I believe it was less than 40% of the cost with the diesel.
How many tractors do you have now?
souNdguy
08-18-2005 04:42:14
 Re: gallons per acre in reply to Jerry (AL), 08-17-2005 19:44:14
Uh.. ( counting on fingers).. 8 so far.. always looking for another victom.. especially a ford 5000.
Soundguy
lonestarjeff
08-17-2005 20:03:38
What engine is in the 255? 3 or 4 cylinder Perkins? Our 165 has the 4 & has always been stingy on fuel too, & darn near zero maintenance. Amazing for a 40 year old tractor.
Jeff
Jerry (AL)
08-17-2005 20:19:20
 Re: gallons per acre in reply to lonestarjeff, 08-17-2005 20:03:38
Four cylinder Perkins.
Bruce (VA)
08-17-2005 18:04:29
It takes me 2 hours & 2 gallons of gas to cut my 2+ acres of pasture; I say 2+ because it really is 3 acres, but I've got probably 1/2 acre or more in the vegtable garden, the wifes flower garden & the herb garden. The N's generally average a gallon an hour, but what you can cut/plow/mow/bush-hog in an hour will vary considerably.
Cargocult
08-17-2005 17:57:30
Depends on how high the grass is/how deep plow/soil conditions, etcetcetcetc!
Dean
08-18-2005 05:38:24
 Re: gallons per acre in reply to Cargocult, 08-17-2005 17:57:30
Bingo!
That said: as previously posted, flathead Ns are not especially fuel efficient. If fuel efficiency is important you will be much better off with a WD AC or, better yet, a modern diesel.
Dean
Tom in MS
08-17-2005 17:49:50
About 3/4 to 1 gallon per acre...These old Ns like this liquid gold pretty good....They claim a Zenith carb. does some better..I have a Zenith but have not run it enough to know...
gahorN
08-17-2005 22:25:55
 Re: gallons per acre in reply to Tom in MS, 08-17-2005 17:49:50
I mow my 13 acre grass runway with one fillup (almost 10 gallons of gas) of my 9N. I use a 5 foot shredder and run in 2nd gear mostly.
Tom in MS
08-18-2005 03:44:58
 Re: gallons per acre in reply to gahorN, 08-17-2005 22:25:55
Sounds like better than average mileage to me..Being a runway you probably keep it cut where it isn"t extremely heavy cutting, which will definitely rob some gallons.. Thanks
gahorN
08-20-2005 21:47:24
 Re: gallons per acre in reply to Tom in MS, 08-18-2005 03:44:58
I just finished cutting it today. The majority of it was about 14" tall (KR Bluestem mostly), but some of it was pretty thick and I had to drop down to first gear for the parking area (about an acre.)
Matt L
08-19-2005 12:05:42
My TO 30 uses about a gallon a hour in moderately heavy mowing in 1st
