wont charge
Ric , Florida
08-17-2005 20:06:19
Have a 51 8n still 6volt Had Gen checked and it is working fine, replaced regulator cleaned all contacts and it still does not charge The only thing different is the amp meter the original had the wire go through a loop on the back of the meter I replaced it with one that has 2 terminals I broke the wire and put one on one terminal and the other on the other. What could be my problem?
Dell (WA)
08-18-2005 00:53:45
 Re: wont charge in reply to Ric , Florida, 08-17-2005 20:06:19
Ric..... ....you replaced yer voltage regulator and it won't charge. Did you remember to "re-polarize" yer voltage regulator to yer gennny?
Just "arc-spark" yer 8N's squarecan voltage regulator BATT & ARM terminals. They're the ones with the heavy wires connected to them. DO NOT mucka'round with the 2-skinny wires. Understand?..... ...respectfully, Dell
