Order Ford 8N Parts Online
48 8n axle leak problem
Reddog48_8n
08-18-2005 18:07:58
i have a rear axle leak that is leaking on the outside of the wheel, i thought axle leaks usually leak into the drum brakes, any thoughts?
JimNC
08-18-2005 19:02:30
 Re: 48 8n axle leak problem in reply to Reddog48_8n, 08-18-2005 18:07:58
The hub has probably been run loose at one time or another. The hub and axle splines are worn a bit. Take the axle nut off and dab some silicone behind the washer and retorque the nut (450 ft.lbs.) I think. If the hub is real loose you will more than likely need to replace the axle and hub. Then mission creep will kick in, and before ya know it, your haulin it to shows :>)
Jim
