Shifter problem
Aberdale Farm
08-18-2005 19:04:54
I have an early 1940 9N with an aluminum transmission top cover. It appears that the shifter has slipped or worn down and is lightly rubbing on the gear below it. Although it shifts ok, I can physically lift the shifter about 1/2 inch if I pull it against the spring. How is the shifter supposed to be held in place, and how do I fix it?
Dale
metalskin
08-19-2005 19:48:08
 Re: Shifter problem in reply to Aberdale Farm, 08-18-2005 19:04:54
i think i have the same problem the shifter has a pin thruogh it that fits in slots the problem is it has warn through and the shifter now rotates completely when i try to shift so i have to hold it in one postion to get it to shift at all the pin is just below the boot. hope some one has a fix for this
jack from wallace
08-18-2005 20:15:20
there is a pin thru the shifter and top cover under the rubber shifter boot
John From Ferndale
08-18-2005 19:53:59
Dale -
I'm looking forward to the Pros From Dover answering this one 'cause I've got the same problem with my '39 9N.
- John From Ferndale
Aberdale Farm
08-19-2005 05:14:21
 Re: Shifter problem in reply to John From Ferndale, 08-18-2005 19:53:59
John,
I think I have just fabricated a temporary fix. I cut and formed a small piece of 1/8" thick steel to fit into the worn area of the top cover. I just wrapped a cable tie around the area where the boot fits to hold the piece of metal in. So far it has lasted about 10 minutes. If it continues to work, perhaps I will clean it up good and add some JB Weld.
If it doesn't work, I think I will take the top cover off and have it welded to build up the worn area.
Dale
John Franz
08-18-2005 19:51:45
Dale -
Paul K in IL
08-18-2005 19:49:25
It is held in place by the spring and the two pins that are on the side of the shifter ball. The problem is the steel pins eventually wear the much softer aluminum and the shifter is pulled down by the spring and rubs on the gears. I have one that does the same thing. I don't know yet how I am going to fix it but it will probably involve JB Weld on the top cover where it is worn. The only time I notice it is when I push or winch the tractor with it in neutral.
Paul K.
