Order Ford 8N Parts Online
One cylinder 8N
SargeVT
08-18-2005 20:30:01
Mowed for about 3 hours with my mid mount mower on my '47 8N when suddenly it dropped from four cylihnders to one in a space of about 150 feet. I got it back to the house on one cylinder with a second cylinder kicking in occaisionally. Found that the new plugs were full of carbon - no oil. Have adjusted the carb according to forum. Comeplete overhaul last year. Has been running the best that it has in years except for a puffing sound from the exhaust at higher RPM. I am wondering if I am compensating with the high speed jet for an air leak in the in-take system. Has anyone experienced this?
Gaspump
08-19-2005 07:07:29
 Re: One cylinder 8N in reply to SargeVT, 08-18-2005 20:30:01
A carb float stuck in the open position can result in that symptom too.
Dell (WA)
08-18-2005 21:36:22
Sarge..... ...you have all the characteristics of "weak sparkies" and 3-hrs of runntime will melt yer squarecan ignition coil's insulative tar and short-out yer coil windings and cause weak sparkies and carbonize yer sparkies.
Your melted insulative tar will harden overnite and you will beable to re-start in the morning, and run for about 1-hr before the tars melt again. Do I haffta tell ya to replace yer squarecan ignition coil?
Don't mucka'round with cleaning yer carbonized sparkies, it just don't pay 'cuz there's invisable no-lead deposits that won't come off. Gitt some new AutoLite AL-437's and check the gap for 0.025"..... ....Dell, yer self-appointed sparkie-meister
souNdguy
08-18-2005 20:47:37
Is it puffing black smoke? In any case.. use propane or wd40 ( well vented area ).. to check for a vacume leak at startup.
Soundguy
