Crank seals on 2N
Tom in MS
08-19-2005 07:10:03
Ordered and got the lower rear rope seal and the neoprene front crank seal..Any special inmstructions I need to pass on to the "Mechanic"?
This lower rope is white..Most times I think I see it referred to as red..Is this the wrong one??Thanks
Russ SoCal
08-19-2005 10:14:20
 Re: Crank seals on 2N in reply to Tom in MS, 08-19-2005 07:10:03
Tom,
I know there are different views on seals, so I distilled the best I've read and got.... Soak in oil for a couple hours or over night. Mash it in real good rolling pin style, making sure it's even. Do NOT trim.
HTH
Russ
Russ SoCal
08-19-2005 10:15:30
 And don't sweat the color in reply to Russ SoCal, 08-19-2005 10:14:20
Tom in MS
08-20-2005 03:07:04
 Re: And don't sweat the color in reply to Russ SoCal, 08-19-2005 10:15:30
Just checking. I think the parts man went to sleep while pulling my order. Several other parts were wrong(for 8N and mine is a 2N) so sure don't want to get inside and not have the right seal. I want this to be a one shot, one weekend deal..
Rick H. Ga.
08-19-2005 07:33:49
Hi Tom,
When I rebuilt my 8N engine, I followed the instructions in the FO-4 manual on installing the crank seals and I have no leaks at all after 5 years. HTH. Rick
Rob
08-19-2005 09:39:53
 Re: Crank seals on 2N in reply to Rick H. Ga., 08-19-2005 07:33:49
Hey Rick, did you cut any off the rope to make them fit?
How many hours you put on them in 5-years?
