Tire pressure
Richard fromSE
08-19-2005 22:52:04
I hate to prove my ignorance again But I can't find this info in my IT manuel.What is the tire pressure for the 11.2x 28 tires on the rear of my 2n?? Checked them today(don't have much else to do after dark) and they did not regester on the gauge.
Dell (WA)
08-20-2005 07:18:51
 Re: Tire pressure in reply to Richard fromSE AZ, 08-19-2005 22:52:04
Richard..... ..yer Ford Owners manual sez: 10-28 (now called 11.2-28) reartires: 12psi. yer 5.50-16 or 4-19 frontires: 26psi..... ....Dell
old
08-20-2005 06:44:55
That can depend on what your doing and what you have on back of the tractor. In most cases 10-15 psi is fine. I have one tractor if I ran that the tires would almost be flat but then it does have a back hoe on the tail, so I run around 20 psi in it.
topsarg
08-20-2005 03:37:08
Richard:
12 to 16 pounds works just fine for a working tractor. Pulling tractors in that weight range usually run 6 to 9lbs.
