Loose studs how to fix?
9N'er
04-13-2001 00:39:13
I have 3-4 studs that hold the manifold on. They keep working free. Upon inspection, the stud is coming loose in the block. It seems that when I tighten the brass nuts, the stud turns in and out.
How do I remedy that? Is there a way to turn the studs in, and then tighten the brass nuts?
Or, should I buy new studs, clean the threads within the block? Your advice and expertiese is appreciated. thank you in advance. 9N'er
Dell (WA)
04-13-2001 10:22:00
 Re: Loose studs how to fix? in reply to 9N'er, 04-13-2001 00:39:13
9N'er..... .since the manifold studs go thru the block into the waterjacket, this is what I'd do.
I'd use a clean-up tap on the block. I'd use new studs. I'd use some stud pucky. I'd still use brass nuts. After the stud pucky cured (24 hrs?), I'd re-install the manifold with new gasket and torque the 7/16-20 5/8 hexhead brass nuts to 27 ft/lbs..... ..Dell
Dell, I got some strange looks...
04-14-2001 11:36:34
 Re: Re: Loose studs how to fix? in reply to Dell (WA), 04-13-2001 10:22:00
I got some strange looks when I went in to NAPA this morning and asked if anyone in there has stud puckey.
I proceeded to tell them I need stud puckey.
After some explaining I said I had no clue what it was, but it had to do with my loose studs.
I said I needed to ream out my stud holes and clean them good and put puckey in it.
All three of them just stared at me, and no one said anything. I felt on the spot, and casually went to another store. 9N'er
well, didja gittany? . . .
04-14-2001 13:16:02
 Re: Re: Re: Loose studs how to fix? in reply to Dell, I got some strange looks..., 04-14-2001 11:36:34
he11, I know it is a commonly used item for small block Chevy V-8's..... ..Dell
9N'er; they wondered if it was a balnk transmitted diesease
04-14-2001 14:21:58
 Re: Re: Re: Re: Loose studs how to fix? in reply to well, didja gittany? . . . , 04-14-2001 13:16:02
I think that's why I got the stares; I think they thought I was searching for something else when I told em I needed a stud puckey; and they all looked at each-other when I asked them if any of them had it.
Al English
04-14-2001 07:20:19
Hi Dell, I thought you advice was good, but I couldn't find "stud puckey" in the locktite catalog. Is that a brand name or an aircraft/aerospace term?...Al English
Look in the Permatex catalog
04-14-2001 08:22:47
 Re: Re: Re: Loose studs how to fix? in reply to Al English, 04-14-2001 07:20:19
gary
04-13-2001 08:11:36
i would try new studs after cleaning up the treads. if worse comes to worse you can heli-coil them. I have heli-coil heads bolts and exhaust manifold bolts on small block chevys and they worked out ok
hope this helps you make a decision
9N'er: hey bg, i'm up at 0340 this morning
04-13-2001 00:50:15
bg, it's 0340 where are you? Are you sleeping in? or working on your 8N right now under those rigged up spotlights? getting it show ready for Gray, Tennesee? 9N'er
