Hot-wiring an N
RickinPickering
08-20-2005 10:09:23
I seem to have lost the keys for my 46 2N. Can someone advise me on how to hot-wire it until I can get replacement keys?
Dean
08-21-2005 10:39:55
 Re: Hot-wiring an N in reply to RickinPickering, 08-20-2005 10:09:23
Be right back---I've got to go out and lock my barn.
Dean
RWK in WI
08-20-2005 17:43:43
If your ignition switch is origional, you can get a replacement key from you NH dealer. All N's through hundred series took the same key.
RickinPickering
08-20-2005 17:35:02
I'll try that tomorrow, thanks guys
RoNofohio
08-20-2005 11:44:00
disconnect the two wires from the ignition switch and twist them together...
Dell (WA)
08-20-2005 10:26:44
Rick..... ...the standard OEM ignition switch is a simple 2-wire key operated switch. It should be intuitively obvious iff'n you follow yer 2-wires back behind the dashpanel you will find 2-terminals that can be connected together to power yer tractor's ignition coil. Simple, eh?..... ....respectfully, Dell
