8N 6 volt frontmount has be losing a bit of power. I was going to change/check points. Yesterday, for the first time in forever it rained/misted all day. Tractor would not start- this is unheard of since I did the Dell's clean/bright/tight with starter ciruit.Tester plug showed no spark. Bypassed ignition switch- no joy. No spark. Voltage at top of coil= 6volts and 1.65-9 Pulled distributer and everything is clean and dry. Points gap looks small and some wear. There was a bit of "electrical smell [grin] inside the distributer- but not burnt electrical smell. Have to pull crab pots now, but will work on it this evening. I'm thinking: Voltage at coil is low (1.6). Time to clean connections at ballast resistor, etc to dist? Then, Should I clean/gap points or just throw in a new set of points and condenser while I have the distributor off? Any thoughts or suggesations. Many thanks in advance.
