Well here it goes.I bought a 42 2N 6V this summer. Everything ran great. She started with just a touch on the starter. But the ammeter didn't work so I put in new one. I followed every wiring diagram and have it wired perfectly. (Problem #1) But it reads -10 when the lights are on and -2 when off. Since then the tractor has ran like crap. (Problem #2) The last owner had cut the wire that runs from the Battery/Generator cutout relay to the resistor block, the reason, I found, is because when connected it melts instantly. So I have left that wire out. I replaced points, plugs, condenser, wiring (except the wire from the cutout relay to the resistor) and I even replaced the coil. The timing is right on by the book. The other night the tractor finally ran but after a while I lost power and barely got her back to the garage. I checked fuel to the carb (good), carb adjustments (by the book), and replaced points, condenser, rotor, and put the old coil back in and finally had some blue spark. (Problem #3) I started her up but she sounded bad, so I checked carb adjustments and she died and sent some smoke out the oil cap. Now I can't get her to start. What is wrong here.
