2n lift arm length
Richard from SE
08-22-2005 14:48:47
Richards got another problem. Do the lift arms on N series tractors come in different lengths???
Already had my 2N. My neighbor had a late 47 8n(front mount)with a brush hog,disc,back blade and scoop. He wanted to sell the lot but would not seperate.I did not want the tractor, or disc so I bought the whole lot and sold what I didn't want.He used the brush hog on his 8n all the time.
Today I pulled the mower out of the grass , greased it all up and hooked it up to my 2. THE DRIVE SHAFT FROM MY TRACTOR TO THE MOWER WAS AT LEAST 6 INCHES TO LONG!!!Also, when I tried to raise the mower more than about 4 inches it jammed into the tires. What gives???
Paul K in IL
08-22-2005 20:18:03
 Re: 2n lift arm length in reply to Richard from SE AZ, 08-22-2005 14:48:47
I really doubt the lift arms are different lengths. They all meet the category 1 3 point hitch specification which specifies among other things the length of the lift arms.
Paul K.
Rob
08-22-2005 17:48:14
The bushhog should come with a drive shaft. That didn"t come in the deal? Your drive shaft is too long and needs cut back. Maybe the six-inches is the ORC. You do have an ORC, right?
Shorten the top link might keep the bushog off the tires. Me, I would not raise the bushog. I never raise mine. And, I have limiter chains on it as a lower limit on deck height and I never have to start the blades in the dirt. I heartily recommend limiter chains.
If you need directions for shortening the drive shaft then go to the bushhog website, pull up the rotary mower manual and it has pictures and instructions. Or answer this post and let me know and I will see if I can link you someway.
Richard from SE AZ
08-22-2005 19:25:24
 Re: 2n lift arm length in reply to Rob, 08-22-2005 17:48:14
Thank you Rob for your reply, Yes the bushhog came with a driveshaft, and my tractor has an ORC,but so did my neighbors 8N. Thats why I don't understand the difference in length. I also have limiter chains that I got help in making off of this site.The reason I wanted to raise the mower is that sometimesI have to jump large rocks. Maybe I'll just walk the property with a wheelbarrow and remove the rocks once and for all. I'm also going to access the bushhog site and see about shortening the drive shaft. Thank U
souNdguy
08-23-2005 06:11:30
 Re: 2n lift arm length in reply to Richard from SE AZ, 08-22-2005 19:25:24
Somethings not right here.. you have a 2n.. your neighbor had an 8n.. both have the same rear geometry.. both had an ORC.. and the mower fits one.. but not the other?
I'd have to guess that either your 2n or his 8n had cut down, or changed out lift arms.
Soundguy
