Order Ford 8N Parts Online
Remote hydraulics for 8N
Oliver Newbie
08-22-2005 22:05:11
Were there ever 8Ns made with remote hydraulics?
Either factory or reasonably common aftermarket part.
Thanks
Willy-N
08-23-2005 06:50:49
 Re: Remote hydraulics for 8N in reply to Oliver Newbie, 08-22-2005 22:05:11
third party image
This was one way, using a Front Hydraulic Pump like on the Loaders. Here is a picture of the Vickers Vane Pump that hooked to the front Crank Shaft Pulley with a short splined shaft going to it. Mark H.
Dell (WA)
08-22-2005 23:50:53
Oliver..... ...remote hydraulics for N-Tractors, kinda YES. After the success of the hydraulicly operated 3-point lift, innovative tractor owners figgered out ways to tap the weak-sister hydraulic system for remote hydraulic power.
By eather chaining down the hydraulic lift arms under yer buttbuckett ...or... by riggin' a hydraulic blocking ball-valve in the hydraulic "stand-pipe" between the pump output and the lift coverplate, you can force yer hydraulic pump flow OUT the corner pressure test port to power a remote cylinder of somesorts. They have even used it to power a light-weight front-end loader. It was originally thought up for hydraulic retractable roadwheels for HEAVY disc harrow transport.
Its NOT as good as a crankshaft pulley operated FEL pump scheme nor is it as "good" as ZANES "live-thang" fanbelt operated supplemental hydraulic pump scheme..... ....Dell
Paul K in IL
08-22-2005 23:18:06
Zane makes an aftermarket kit for the 8N that I have heard good things about. Check it out on his web site:>Link
Paul>Link K.
