Order Ford 8N Parts Online
8n 3 point
rgarner38
08-24-2005 08:13:02
Maybe someone can help me, I am repainting my 1949 8nand was going to pull the 3 point rocker off but there seems to be a bushing thru the rocker have looked on these web sites to try and find it but can"t, can someone tell me if the bushing is supposed to be there or is something wrong
Thanks
Dell (WA)
08-24-2005 08:38:57
 Re: 8n 3 point in reply to rgarner38, 08-24-2005 08:13:02
garner..... ...not quite certain why you think you need to remove yer 3-hole rocker from yer 8N's 4-doggears diffy. Most painters just paint it in place. The approx 1-1/4" dia hollow bushing that holds the 3-hole 3-point top rocker is for the "bendable" 10" jingle-bars pin that goes thru the dogg-ears. The adjustable length jingle-bars hold the 11-hole drawbar at a constant height and is usefull for backing a 4-wheel haywagon into the barn..... ...Dell
