There are time I just love to hate a frount mount
old
08-24-2005 13:01:30
Well I found the problem, points had sliped. The old screw let me down so I replaced it. I also did a carb rebuild and I did a stupid thing when I did. I left out the brass tube in the carb, it would run but I could adjust the carb any to speak of so I fuigured I had missed something. Took it off and then found the brass tube laying there. Put it in and it now purrs again. Bad thing is I have done over 100 carbs and never forgot to put that in.
don b
08-24-2005 13:38:08
 Re: There are time I just love to hate a frount mo in reply to old, 08-24-2005 13:01:30
Old..... did you put a dab of locktite on the screw.If the threads are worn in the dist. plate,it will loosen up again. don b
old
08-24-2005 13:46:54
 Re: There are time I just love to hate a frount mo in reply to don b, 08-24-2005 13:38:08
No but I did use a screw that was about twice as long, maybe that way it will get a good bite
Dan
08-24-2005 13:53:32
 Re: There are time I just love to hate a frount mo in reply to old, 08-24-2005 13:46:54
WARNING - many have made the mistake of putting a longer screw in the breaker plate and it sticks down too far under the plate and blocks the advance weights from moving.
Dan
Rick H. Ga.
08-24-2005 13:25:19
Old, you are not slipping, you just got in a hurry.
If you have done 100 carbs, you ought to be a pro at it by now.
Of course, with 20 tractors you need to be a pro:-).
Best regards,
Rick
