First, thanks for the help!It appears that the ends of the ballast resistor were corroded and it was dropping too much voltage. In addition, the ignition switch, although not bad quite yet, showed it was also dropping some voltage (varied when jiggled). Put on the spare ballast resistor and it fired up. Then replaced my LAST ignition switch. Going to go with a marine switch in the future. The voltage at the top of the coil was 1.6v max before I replaced parts. It is now 3.4v. I reset points after getting it running again. The gap was small due to rubbing block wear. The point set and condenser are fairly new. It seems to still stumble a bit under heavy load. I rebuilt an old MS carb and will put it on just to see how it works. I did the carb with a complete kit for the fun of it trying to learn techniques including left-handed drilling, tapping, electrolsis, phosphoric acid sprays, etc. It's good to learn new techniques. I hope..... .
