Ravi..... ..this is amazing. I'm not certain why yer Sherman's splined input shaft is NOT compatable with yer splined 8N clutch hub, it should be. Is yer clutch disc "centered"? Use yer old 8N tranny input shaft as a centering guide and release yer pressure plate attach bolts so you can jigger yer clutch disc into centering alignment with yer flywheel pilot bearing. Remember the clutch hub is an "off-set" design and the LONG SIDE is tranny side. Retighen yer pressure plate bolts 18ft/lbs after re-centering yer clutch disc. Failing to mate yer clutch hub to yer new Sherman splined input shaft, (did you try it all by itself?) I'd remove the 4-bolt inputshaft retainer and carry BOTH the input shaft and clutch disc to an INDUSTRIAL CLUTCH house and see iff'n they could "mate" the hub to the shaft with some off the shelf clutch parts. And NO, you shouldn't haffta replace yer clutch pressure plate. Remember to replace the Sherman input shaft seal, ($3, cheap) with p/n 8N-7052A or A1,A2,A3,A4 (NAPA NOS-17645). Itza 4-bolt, 15min job..... ...Dell
