NAA Exhaust Battery Questions
ryanNva
08-28-2005 18:35:02
First off, i am wondering if there is some kind of rubber hose that can be used to connect the muffler to the tailpipe (piece coming out of the muffler)? I was thinking of using maybe radiator hose but am thinking that the temp right after the muffler might be too hot. Any thoughts.
The battery question is simpler. What size cables should be used for the ground/positive/starter??
thanks,
Ryan
Dan
08-28-2005 19:06:50
 Re: NAA Exhaust Battery Questions in reply to ryanNva, 08-28-2005 18:35:02
The tailpipe section fits inside the opening on the muffler and is squeezed together with a metal clamp. DO NOT USE RUBBER!
The correct size for the battery cables are 1/0.
Dan
