Order Ford 8N Parts Online
Size of the 8ne10306 dropping resistor
Rob
08-30-2005 18:53:12
What are the ohms and watts?
Bob
08-31-2005 00:01:24
 Re: Size of the 8ne10306 dropping resistor in reply to Rob, 08-30-2005 18:53:12
About 1.6 Ohms.
It's dropping about 6 Volts, and carrying a current of about 4 Amps, so it's dissipating at least 24 Watts.
Phil (NJ,AZ,Sask)
09-01-2005 02:36:50
 Re: Size of the 8ne10306 dropping resistor in reply to Bob, 08-31-2005 00:01:24
Bob, The current response of ALL the Ballast Resistors are Identical. They all limit @ 3 Amps
The only diffence is the amount of circuit (ballast) resistance @ 3 amps
That is why if is so difficult to select the right Ballast Resistor. If you select one that is to large the circuit current will decrease and your ignition will be marginal. If you select one that is to small the ballast will overheat and fail.. this "may" cook your coil.
The Out of Circuit Resistance of the 8ne10306
ballast should measure ~1.7 Ohms but that assumes that the the coil used is a 6v OEM Front Mount (.75 ohm).
The way that I would measure the (in circuit) 8ne10306 resistor is to measure the voltage drop across the OEM Ballast (Known Response Curve) to determine that the circuit operating current is ~ 3 amps. If the Voltage drop is ~ 3.5V across the OEM ballast you have a good match.
NEVER USE A FIXED RESISTOR IN PLACE OF A BALLAST THAT IS GREATER THAN DELL'S .5 OHM
Hope this helps,
Dell (WA)
08-31-2005 08:02:28
good electrical engineering practice would dictate yer resistor as used, be rated at least 50-watts. This is a "physical size" solution. Low-ohm, high-power resistors are NOT precision resistors. I seem to remember 1.5-ohms, but it is NOT critical.
Any autoparts store will usually have their own product line version of 12-to-6volt conversion resistor. Often used for 6-volt heater fan motors; windshield wiper motors; instrument panel gauges; sometime old fashoned vacuumtube radios. Leave alone the necessity of 6-volt squarecan ignition coils..... ...Dell
Rob
08-31-2005 03:02:56
Thanks.
Is that ohms measured?
souNdguy
08-31-2005 07:00:29
 Re: Size of the 8ne10306 dropping resistor in reply to Rob, 08-31-2005 03:02:56
Probably an observed number. Given that system voltage is a range.. that will make disipated power a range, as well as current flow.
I don't know the thermal properties of the resistor.. if it is temp stable, you could take an inline amp reading.. a voltage measurement.. then fairly accurately calculate ohm value.
If it is not a temp stable resistor.. the you could do that same test twice.. one when cold, and one hot.. then establish an ohm range, based ona stable votlage, and the other units varrying.
Tolerance will also be an issue on the resistor, I've seen many power resistors that have fairly high tolerance range.. 20% or more.
Soundguy
Rob
08-31-2005 07:36:49
 Re: Size of the 8ne10306 dropping resistor in reply to souNdguy, 08-31-2005 07:00:29
If I had one, I would measure. I was wondering if anyone had measured or seen the specs.
