Ryan..... ...welp, that is definately a picture of a NAA genny and yours may or may not be a 12v genny thats been converted by a shop by changeing field windings. Its called a "stealth" conversion. My betting is it ain't been converted but I've been wrong before. Theres many a tractor that the PO (Previous Owner) just used a 12v battery and every nite connected a 12v charger to it and didn't even worry about changeing the electrical gennerator system to 12v. Your tractor can run for hours on a 12v battery; most 12v battery hold about 900amp/hrs and yer ignition only takes about 3amp/hrs. Most 12v conversions use the common Delco 10SI aluminum framed alternator with built-in alternator. (donnno what an alternator looks like? check yer 12v belchfire V-8 or rice-rockett 4-cyl) Use the 3-wire version with idiot light 'cuz it charges at low rpms of tractor engine. The deceptively desireable 1-wire version needs about 1800rpms before it starts charging. I don't like jazzin' a cold engine to 1800rpms, do you? And YES, you will haffta change to a NEW alternator mount iff'n you convert. Keep tellin' ya, I flunked mindreading and you've gotta do a better job describing yer abomination of electrical miss-mash..... ....Dell
