Proper Resistor for 12 volt coil????
Roger A. Polzin
04-14-2001 18:13:31
Just what is the proper resistor to get for a 12 volt replacement coil on a front distributor and what volt ratings should I have after resistor, with and without points open? I can't find one clear answer looking thru the archives and I'm getting a headache! Please Help
wrenchman
04-16-2001 00:09:30
 Re: Proper Resistor for 12 volt coil???? in reply to Roger A. Polzin, 04-14-2001 18:13:31
go to NAPA and get ign.resistor for mid 60's chrysler car or truck.worked for me.(about 10yrs now).
Jim is correct that Dell is correct AND bj/8N/mt
04-15-2001 07:28:45
can you identify the manufacturer or even the vendor of the coil you have
if so see if you can get a definitive answer from them as to what resistor you need
at least that way you have somebody to blame when the smoke check goes bad
your mileage may vary
Jim, Dell is correct and ...
04-15-2001 06:18:33
Roger Dell gave a very good history and explained the situation better than reading the archieves. I have been in you shoes last winter.
The most important fact is 13 volts MAX. Which means with the engine not running (Dell says) "Read the voltage at the ignition coil terminal, its more accurate anyways. About 10-11 volts (11.5 max) with the points closed and engine not running. Battery volts with the points open."
I achieved this (10.8 volts) on my system by using two of the p/n 9N 12250 resistors in parallel, as suggested by another electrical expert - Phil. It worked for me, I hope it works for you.
Enjoy, Jim
Dell (WA)
04-14-2001 18:43:07
Roger..... ...The reason I can't give you a straight, definative answer is: nobody ever told me.
Originally, the 12 volt frontmount ignition coil was supppost to be straight with no resistances needed. Everybody thought that was great. Except the dealers and the coil manufacturer who all of a sudden had beau-coup complaints about lousy burned out coils. mumble-mumble
So they started including an instruction sheet giving the correct value of current limiting resistor needed, which unfortunately for you, is not the same value as the infamous "ballast resistor" mounted on the backside of the dash.
At one time, the new 12 volt frontmount ignition coils came with somesort of instructions sheet in 8 different languages 'xept 'merican. Nobody ever reads the instructions anyways.
I can tell you this, there used to be a tag on the 12 volt frontmount ignition coil that said "13 volts MAX". Believe it. And since good 12 volt alternators will put out about 14.7 volts, guess what is going to happen to your nice new ignition coil?... Its OHMS LAW baby!!!
Even more compounding is the fact that most commonally available ohm meters are not very accurate at low ohms, you need $500 lab grade ohm meters. So what to do?
Bottom line, you need about 0.4 ohm at about 20 watts (burnie-burnie) to keep your new 12 volt coil from burning out. And NO, I can not give you a part number. Diffferent resistor makers will have different part numbers for the same electrical value resistor. And no I can't tell you where to get it or where to mount it, its all too subjective. Except mount it where it CAN NOT melt anything..... ...Dell
