Hydraulic lift control arm bent
Ralph ND
04-14-2001 18:21:39
The hydraulics on my 48 N didn't work when I got the tractor this spring so today I took off the lift cover assembly and found the lift control arm out of the hole in the rocker lever. (When I drained the oil there was quite a bit of water in the oil}. My guess is that they tried to move the lever when it was frozen. Question: is the lift control arm supposed to have a bend in it toward the front or is it supposed to be straight? In my FO-4 manuel it appears to be straight.
Steve IA
04-15-2001 03:08:56
 Re: Hydraulic lift control arm bent in reply to Ralph ND, 04-14-2001 18:21:39
Yup. Straight it is supposed to be. I straigtened mine with a big vise and a 3# hammer. Slowly and gently. HTH Steve 8N 169302
